0 members (), 101 guests, and 109 robots.
Page 3 of 3 1 2 3
#33789 01/28/04 11:42 PM
Anonymous
Unregistered
I don't tape wirenuts but one thing I do when making up exterior boxes, which I thought up myself, is I always push the wirenuts into the box right side up so they won't accumulate moisture. After opening a lot of old exterior boxes and seeing a water line inside a half inch deep, I think cutting a small weep slot in the bottom of the cover gasket is a good idea too.
#33790 01/29/04 02:09 PM
C-H Offline
Can somebody explain how these work? "No junction box needed" I took it to be a joke at first:
http://www.labsafety.com/store/product_group.asp?dept_id=1211&parent_id=224
#33791 01/29/04 03:28 PM
I also only use the Wing Twist from Ideal. I pre-twist stranded, but not solid. I twist them until my wrist cracks, like sparky66wv said many moons ago, and tug on each wire afterwards. No tape here. [Linked Image]
As far as the King Safety Direct Burial Wire Connectors are concerned, they must be for south of the border usage!!! [Linked Image]
[This message has been edited by Mean Gene (edited 01-29-2004).]
#33792 02/25/04 12:46 PM
C-H Offline
I came across an FAQ for the "no junction box needed"-connectors.
http://www.kingsafety.com/faq.html#Q5
What kind of wire could you use with these?
#33793 02/25/04 01:04 PM
C-H,
These connectors are for low Voltage applications (max 30v) such as irrigation control wiring and low voltage pathway lighting. I don't know the specific wire terminology.
#33794 02/25/04 02:01 PM
C-H Offline
Bill,
the specification says 600V. [Linked Image]
http://www.kingsafety.com/dryconn_db_blue_spec.pdf
#33795 02/25/04 06:35 PM
i don't tape wire nuts but on stranded wire i do tape the wire its self about a inch back with two raps of tape from the nut. I do this becase of stranded be so easy to pull apart even if you use ideal twister. I know some of you have got into a 12x12 box to trouble shoot
and fire starts to fly. Taping the wire's back a inch or two it would help.
I make the people on my jobs do this and twist solid wire also.Nobody thinks of the poor S>O>B that has to come in later on to fix something. Big guy
#33796 02/26/04 10:01 AM
I do tape the connections I make in motor "peckerheads". I know there is no reason why I should, but old habits die slowly. Many of the old motors have split bolt connections, which require taping. These are always a mess when we send the motors out for maintenance. But, they pay me the big bucks for getting my hands dirty. (or they used to)
Earl
Earl
#33797 02/26/04 06:58 PM
I tape all splices back 2inches from the wire nut. I always pre twist and have a trick when splicing solid to stranded. I would say but it's to hard to say very easy to show.
#33798 02/27/04 03:52 PM
SJT Offline
I've gotten into the habit of taping the receptacle or switch (making sure the terminals are covered) with scotch 88, when ever I use a Gem box with madison clips. I try to make the clips as tight as possible, but I wouldn't want one of those clips to come in contact with the device. Just a habit.
Page 3 of 3 1 2 3
