There's quite a variety of 1Ø Motors.
The common Split Phase Induction Squirrel Cage Rotor type come in several flavors:
<OL TYPE=A>
[*] Split Phase-Resistance Start (no "compensation" in the Aux. Circuit,
[*] Split Phase-Capacitor Start (large value Capacitor in series with Aux. Circuit),
[*] Split Phase-Capacitor Start/Run (large Cap for starting, smaller Cap for running),
[*] Permanent Split (Phase) Capacitor-or "PSC" for short (Capacitor and Aux. Circuit always connected),
[*] Variations of the above for General Purpose, High-Torque and Two-Speed Pole Changing.
</OL>
Other Induction types include:
<OL TYPE=A>
[*] Shaded-Pole types (as previously discussed). These Motors do not have Starting Switches or Capacitors for the
Aux. Circuit, and the Aux. Circuit is always active in the operation via induction,
[*] Hysteresis Motors (typically used for Clocks and Phonographs). These are true Synchronous type AC Motors,
[*] Reluctance Motors - also Synchronous type Motors.
</OL>
1Ø AC Commutator "Universal" Motors include:
<OL TYPE=A>
[*] Series connected ("Simple Series"),
[*] Compensated Series connected,
[*] Repulsion Motors ("Simple" and "Armature-Excited"). These are Commutator type Motors with no external
connection to the Armature.
[*] Versions of the above with or without a speed Governor.
</OL>
And of course - DC Commutator Motors!
For the Repulsion Motors, the series AC circuit flows only thru the windings, not thru windings and armature.
The Armature is short circuited outside of the brushes. On the Armature-Excited type, there is a Variable Ratio Transformer in series with "½" of the Armature Circuit (it has 4 poles, or 4 brushes).
Variations of the Repulsion Motor are the Squirrel Cage Repulsion Motors. These "Brush-Shifting" Motors come in Series and Shunt wound arrangements, along with Single and Polyphase setups.
I would really like to add Schematics and description text for these types of Motors in the Technical Reference area.
Maybe sometime soon... maybe not
![[Linked Image]](https://www.electrical-contractor.net/ubb/wink.gif)
Scott35
This Message Was Sent From:
Scott E. Thompson / Thompson Electric
Via PC#5 (W/S P55C.LOC05.001)
E-Mail: adst@pacbell.net
http://www.setelectric.electrical-contractor.net Always Look For This "Sigfile" Or One Similar.
Definitions:
Control (CON-TROL) n.;
A Very Small Prisoner That Lives Under A Bridge.
Asset (ASS-ETTE) n.;
A Little Donkey.
Ascot (ASS-COTT) n.;
A Little Bed For Donkeys.
Naval Destroyer (NAYEE-VULE DEE-STROIE-EER) n.;
A Hula-Hoop With A Nail In It.
Trivia Question:
Q: What Makes The Tower Of Pisa Lean?
A: It Never Eats.
