Wow, you guys are bad luck, dont stand near me at the craps table
![[Linked Image]](https://www.electrical-contractor.net/ubb/wink.gif)
We have never had any major issues with eletronic ballasts. I do most of our warrentee repair and in the last couple years I can only recall replacing 1 bad electronic ballast and 1 electronic that was noisy. Thats with probably a thousand ballasts installed in new fixtures.
I personally love electronic ballasts, run cooler than magnetic, I believe operate at a higher frequency (no flicker), not as noisy, use less power, seem to usually start faster.
I would check voltages and neutral connections. Or maybe you just got a bad batch?
We did have a problem with a single building we wired 10+ years ago. One room a very large building was always going through ballasts, even though the rooms fed before and after it were fine. This room was even temperature controlled 24/7 at 68 degrees. I checked every connection, replaced every fixture completely and still had the problem in the same room. I ended up just running a new curcuit over and that seemed to fix the problem. Still to this day don't know exactly what was going on.
