One "old-timey" material is Cool-Amp ConductoLube. Unfortunately, it does not contain essential loquat and okra extracts—only silver dust in mineral oil.
Who pays $150/MWH for firm? Even peak? Based on our 3000 MWH per month we pay about .024$/kw and whatever market price is for above our firm of 3.617 MWH.
Electech, not to beat you up or be picky, but your calculations are based on 24 hours a day/7 days a week of electrical usage. Are most of the locations you've done, running 24/7?
The application of Micro-Lube decreases the resistance about 3.5 MICRO ohms? At 100 amps, and a starting resistance of .001 ohm that decreases voltage drop from 0.1 volt to 0.0965 volt. A whopping reduction of 0.0035 volt. I'm going to take a vacation with the savings.
Bjarney, there's also this goo that Caig makes (from the people that brought you DeOxit switch and potentiometer cleaner spray) that is graphite impregnated (there's also a plain version).
It's called Cailube and supposed to seal and protect electrical connections.... http://www.caig.com
The magic 'Bullet' for terminations, seems to have all the Holistic ingredients for what ails ya. How about Electro-Saf mixed with a little K-Y jelly and graphite. ?
