0 members (), 603 guests, and 6 robots.
Page 3 of 3 1 2 3
#23886 04/01/03 06:22 PM
No animals anymore. Just a big old historic barn that the local yokels are trying to preserve. The service is the most structurally sound part of the building!
#23887 04/02/03 06:10 PM
all code quagmires aside, i often wonder what is the better job in ohmic terms.
not having the scratch for a good tester, i'll probably never know.
#23888 04/02/03 07:13 PM
My water-well casing reads a solid two ohms by the three-point method, but the place was built in 1935. Drillers haven't used steel for domestic-well casing for ~30 years in this area.
Regardless of test numbers, nothing can prevent destruction from a direct lightning hit.
[This message has been edited by Bjarney (edited 04-02-2003).]
#23889 04/02/03 08:18 PM
Z
What do they use now?
#23890 04/03/03 12:47 PM
Thank you for the info guys. A commercial property is completely covered by a 6 inch thick concrete slab. They saw cut the concrete for plumbing equipment. I will drive the ground rods in the trench area and the acorns will be buried below the concrete. I was worried I'd have to block out the concrete for access to the acorns.
Bob
#23891 04/03/03 06:45 PM
zapped — for 8-inch or less casings [maybe larger] — it's PVC.
#23892 04/03/03 06:50 PM
As far as test instruments, local AEMC and Megger reps may be able to demonstrate their wares on your jobsite. Short-term rental may be another option.
#23893 04/12/03 10:51 PM
Bury the rods in the concrete! My inspector claims the concrete has the right moisture content and that it stays steady.
Phil
Page 3 of 3 1 2 3
