ShoutChat Box
power failure but lights dim
by gfretwell - 08/14/20 04:16 PM
HVDC Greece to Crete
by gfretwell - 08/06/20 02:28 AM
310.15 (B) 7 Feeders
by HotLine1 - 07/31/20 02:29 PM
What would be the ideal solution?
by Fleppin - 07/21/20 12:42 AM
NESC question
by gfretwell - 07/16/20 04:17 PM
Facebook follies, bad wiring
FPE in Germany pt.2
0 registered members (), 8 guests, and 24 spiders.
120/208 gives 240? please clarify #220885 07/11/20 01:35 PM
sophocles Offline OP
My apartment house has 120/208v Wye connected (4 wire plus ground) service from the utility. Apartments have 120/240 service. we can easily measure the 120v from phase to neutral - and I can comprehend the math that shows 208v between a phase and the imaginary point directly opposite the phase.
i can't see how this provides the 240v part of 120/240 to the apartments.
i am certain this has been addressed 100 times before, and would appreciate somebody helping this dummy for the 101'st time.
thanks!
Re: 120/208 gives 240? please clarify [Re: sophocles] #220887 07/12/20 10:05 AM
JoeTestingEngr Offline
Is there a room where they might have some 208 primary, 120/240 secondary transformers?
Re: 120/208 gives 240? please clarify [Re: sophocles] #220888 07/12/20 03:08 PM
gfretwell Online Content
Are you sure it isn't 240/120 center tapped delta?
Re: 120/208 gives 240? please clarify [Re: sophocles] #220892 07/13/20 12:58 PM
HotLine1 Offline
120/208 3 phase, 4 wire secondaries from POCO transformers is common for multi unit apt construction.
Re: 120/208 gives 240? please clarify [Re: sophocles] #220898 07/14/20 01:03 PM
Did the OP actually see 240v? I know we always had this issue in computer rooms that were in light industrial area where they used Delta Vee. It was necessary to actually verify the voltage before you believed what the customer said. We have burned up some stuff when we assumed 208 wye.
Re: 120/208 gives 240? please clarify [Re: sophocles] #220904 07/15/20 01:33 PM
HotLine1 Offline
Greg:
The OP lists his occupation as retired. I read his post twice and was going to reply with the usual comments.
Secondary actual voltage, load, lowest secondary voltage with 'heavy load'. Actual voltage at apt panel; etc.
I stayed silent on this
As you know the 240 volt items are AC, maybe cooling, maybe water heater. They tolerate <240 volts
I have not heard of any issues from the +/- 600 apt units that have been built in the last 2 years.
Re: 120/208 gives 240? please clarify [Re: sophocles] #220907 07/15/20 06:07 PM
If he is really seeing 240v with a reliable meter, I think we can agree this is not normal 3p wye. It is more likely if measured that "240" is really more like 208. You are right that a lot of equipment has a wide enough "mouth" to take both but other stuff will need to be tapped to the available voltage.
Re: 120/208 gives 240? please clarify [Re: sophocles] #220911 07/16/20 03:00 PM
HotLine1 Offline
He may be using a 'wiggy' type tester!
2020 National Electrical Code
Code (NEC)
2017 Master Electrician Exam Preparation Combos
2017 NEC Electrician
Exam Prep Combos:
Master / Journeyman
CharlieE
CharlieE
Indianapolis
Show All Member Profiles
BigB 2
wa2ise 1
268,668 Are you busy
203,001 Re: Forum
191,366 Need opinion
Powered by UBB.threads™ PHP Forum Software 7.7.3
