0 members (), 517 guests, and 11 robots.
#22095 02/19/03 09:37 AM
Huh? A home office would fall under "simmilar room or area of dwelling units" as would breakfast room breakfast nook, billiard room, reading room, etc. All not specified directly yet receptacle placement rules would apply. George are you an electrician? Just curious.
#22096 02/19/03 08:37 PM
Electricmanscott ---
I used to be licensed.
Your defintion of "similar" may or may not be correct in your juristiction. It is not correct in my buildings.
You might note that most building codes only require 200 - 300 sq ft of habitable space in a residence. The rest of the space can be denoted "non-habitable" on the plans and again the 12' rule does not apply.
What a stupid question to fight over.
Foca Se ---
Ask your AHJ to waive the requirement.
#22097 02/19/03 08:41 PM
The AHJ has the final say on such matters not the homeowner.
#22098 02/19/03 09:47 PM
Seems to me that for less than what it cost to stand and argue with the ahj about where a recep should/shouldn't be,You could put them in per code and be done with it.
#22099 02/19/03 10:17 PM
GaSparky56:
WELL SAID
Sometimes the amount of energy and time that is wasted is outrageous.
