0 members (), 665 guests, and 14 robots.
Hamacho Offline OP
Hello!
I want a light inside my closet that activates (lights up) when I open up the sliding door.
So my idea is that when I open the door, a connection breaks and allow electricity to flow to the light. Anyone here that has any thoughts on how to do this? Because I dont.. I'm very open to learn though.
The only thing I can come up with is that the door pushes down a button when it's opened to a certain level. But I found the other way to be more practical.
Thanks on advance!
-Hamacho
Why not use a switch that closes when the door opens?
I could draw you a circuit that would do what you want using a relay but it seems like the long way around a simple problem.
Purpose made closet door switches make when the pressure (of the door) on the switch is removed.
https://www.tlc-direct.co.uk/Produc...__RsK-HGAx3XMnsMvQqnz2ZhTJRoCZakQAvD_BwE
