0 members (), 861 guests, and 10 robots.
Trumpy Offline OP
Check this out:
It is on Facebook, if you can't access the video, let me know:
[color:#3333FF]Strip Install[/color][/b]
I'm not sure where in the world this comes from, but I'm not sure it would comply anywhere.
It would be a great way to install surround sound speakers though.
Some of this is similar (vaguely) to FCC here in the states. FCC (Flat Carpet Cable) is not 'common', but it shows up on occasion. Only to be installed under carpet tiles.
I think this is Brazil or something like that. I suppose it would fail standards testing in most civilised countries due to its lack of mechanical strength.
Interesting.
I wonder what happens when someone forgets it's there and tries to hang a picture.
BZZZZZZZZZZZ.
Ghost307
Please tell me that was a joke I cant believe something that dangerouse is allowed did anyone else notice the complete lack of earthing? I think this might be ok at 12 volts but not on 220/240 imagine if you had a damp wall.
Nope...it definitely exists (although I wish it didn't).
Its use on walls is VERY limited (fortunately), and it can only be used on the floor (legally) if the floor is covered by carpet tiles less than 1 meter square.
https://www.youtube.com/watch?v=J-zLUa8LJXw
Ghost307
Along with Ghost307 comments, the FCC also has a metal 'sheet' that goes over it, along with an adhesive tape.
If I remember from the last time I installed it, there's a underlayment, the FCC, an overlayment, the sheetmetal, and the wide tapelike cover.
Also, it is not an 'easy' install, but was a PITA!
Hmmm...I should look at the youtube link???
edit: 4 min of the 30+min is enough for me.
Stuff I remember was similar, but a different mfg.
Sorry...I tried to find a shorter video.
Ghost307
