0 members (), 247 guests, and 14 robots.
#21784 02/10/03 07:29 PM
Anonymous
Unregistered
Can you place romex in EMT? Where in the code does it say you can or cant? I have asked this question to 3 electricians and got 3 different answers. Its a 40' run of 1/2"emt with 10/3 romex going into it. Thanks for any help.
#21785 02/10/03 07:48 PM
WildTurkey101;
check out page 70-617 of the 02' , notes to tables #9
btw~ welcome to ECN
#21786 02/10/03 07:59 PM
99NEC Ch.9 Notes to Tables “A multiconductor cable of two or more conductors shall be treated as a single conductor for calculating percentage conduit fill area. For cables that have elliptical cross sections, the cross-sectional area calculation shall be based on using the major diameter of the ellipse as a circle diameter.”
Not sure if this would be the case for “Over 2 Wires: 40%” or “1 Wire: 53%” fill.
10/3 NM-B will probably need larger than ½-inch tubing.
#21787 02/10/03 08:24 PM
WildTurkey101...( I have asked this question to 3 electricians and got 3 different answers.)...so what was their answers.
is the 10/3 cable being installed in the conduit for protection against physical damage.?
sparky ....what page. [Linked Image]
#21788 02/10/03 08:40 PM
F
wildturkey :
for 10/3 romax cables(wires) you have to run it in 3/4 emt conduct. btw 1/2 inch conduct wont fit with 10/3 belive me it is a pain in the butt with that but i did check on nec 99 version it say same way check the area fill for conduct
merci marc
#21789 02/10/03 09:29 PM
Anonymous
Unregistered
Lighthouse, the answers were "yes you can", "no you cant", and "what the heck are you talking about". The 10/3 is running down the side of a house and I was going to place it in some EMT. I just wanted to make sure I wasnt breaking any code rules. Thanks for all the quick replys.
#21790 02/10/03 10:10 PM
Is this running down the inside or outside of the house?
#21791 02/10/03 11:14 PM
Anonymous
Unregistered
Jim, it is running along the outside of a house.
#21792 02/11/03 07:51 AM
334.15 2002 code
#21793 02/11/03 08:07 AM
just to make your morning i'll ask if if needs to be grounded....
