0 members (), 1,316 guests, and 21 robots.
Originally Posted by gfretwell
OK do you want one detector to always be for "off" and the other "on" or do you want it to toggle whenever either is triggered?
The former is how I have it designed. What I am designing has a reciprocal motion - I will need each sensor to do only one thing. Sensor one will turn on an outside circuit when activated, and sensor 2 will turn off that outside circuit. They will never operate the other way around.
The latching relay may be the simplest solution. It has 2 coils. One picks the relay, the other drops the relay. Getting from the photo detector to having the current to operate the relay coils will depend on which one you chose.
I am sure you can find something that would operate them directly.
Look into P&B KUL series latching relays for what you need. Potter & Brumfield was gobbled up by TE Connectivity, which used to be Tyco, so don't let the different mfg. names throw you off. I don't remember you mentioning your desired operating voltage yet and that really does impact the best fit of many possible solutions.
Joe
