1 members (HotLine1),
128
Posts: 984 Likes: 1
Whatever the manufacturer says the maximum lamp rating that it is designed for. Generally for medium base Edison sockets that is usually 150 Watts (no 125% needed).
Ghost307
Posts: 9,931 Likes: 34
Most regular edison base lamp holders are marked "250w". That seems to be the biggest bulb you can buy without going to a mogul. I have a 200w in the lamp next to my chair as we speak (on a dimmer). I am old and 200 might not be enough if I am doing some close work. "Get out of my light"
Posts: 7,382 Likes: 7
Greg: A 200 watt bulb? Last I was in 'big orange' incandescent bulbs looked pretty scarce. It's even tough to find a 60 watt yellow bug bulb.
That must be a local thing. I have no problem buying 150s and 200s. It is the 60 and 100 A19s that were phased out.
Shelves are full of all kinds of CFLs and LEDs.
Even saw some LEDs on 'clearance-markdown'!
I'm hunting for an equivilent 60 watt CFL 'bug bulb'. The two I recently got seem to be eq. to a 15 watt incd.!!
If they are phasing out the regular A19s there you can always go for a halogen replacement.
