0 members (), 185 guests, and 17 robots.
Heat guns, at least basic non-thermostat models are dirt cheap and even the cheapes China models last surprisingly long. Mine is more than 10 years old now and cost €29 back then (roughly $40). I don't use it on a daily basis, but if I do use it then it's for paint stripping, so it might run for hours on end. It always sounds like the cheap bearings are about to give up but it works like a charm. I expect at some point either the motor or the switch will fail, that's how most cheap hairdryers bite the dust (also had some fan blades break).
I guess a heat gun will work on the shrink kits want it?? I've never used one so I don't know. Hope it gets hot enough.
Should do. Some heatshrink tubing can even be done with a hairdryer and heatguns get MUCH hotter.
When I did the splices for my well pump it looked like about all a propane torch could handle. This was not typical shrink tube. I was also not really impressed with them. I guess it is working but I am not sure how I would know. These are not on a GFCI
Sparky,
I have used that splice kit for many types of underground repairs for years and I have never had a call back because of them. Is it UL listed for the application? Not sure, too many years ago to remember.
