0 members (), 190 guests, and 10 robots.
HotLine1 #209874 05/09/13 12:49 PM
Hi,
I misquoted the following post:
"Idrive a ground rod run #6 to meter base this is the GEC correct? The GEC is run with circuit conductors..an equal potential grid is a grounding mat/grid connected to ground rods..for the whole plant they have 4/0 in the ground and #2 insulated ground for grounding tanks, motors or building steel..thanks for the replies.."
I meant to say: "drive a ground rod run #6 to meter base this is the GEC correct? The EGC is run with circuit conductors..an equal potential grid is a grounding mat/grid connected to ground rods..for the whole plant they have 4/0 in the ground and #2 insulated ground for grounding tanks, motors or building steel..thanks for the replies.." sorry for the confusion and thanks for the correction!
Don't drive and TEXT! Drive now TALK LATER!
Workgear for Electricians
akmaster #209879 05/09/13 03:20 PM
No problem! That's why we are here.
