0 members (), 1,042 guests, and 10 robots.
Page 4 of 4 1 2 3 4
harold endean #209107 03/07/13 10:43 AM
Shortcircuit:
Yes, modifications to buss cause issues with the listing. Alas, it has been 'common practice' for some time.
Dependent on having a PE/EE provide methods and materials, and a signed sealed drawing, it is acceptable in most cases.
A few jobs required the mfg to provide the materials and make the mods, and provide UL field certification. That is when $$$ is no object, as it it very costly
Workgear for Electricians
harold endean #209250 03/19/13 12:23 AM
bump Harold, how did this job work out?
harold endean #209303 03/23/13 11:52 AM
I went back yesterday. I had a new set of drawings that showed the correct way it was all actually installed. There were some 800 amp quick blow fuses before the tap for the PV system. So the feeder to the PV was protected. They also didn't tap the bus, but bugged the incoming wires. II have signed and certified drawings from an EE for this job.
harold endean #209308 03/23/13 12:04 PM
Thanks for the follow up Harold.
The EE still has to follow the 120% rule.
harold endean #209752 04/23/13 12:02 PM
bumpHow did this work out Harold?
harold endean #209805 04/29/13 01:19 PM
Short circuit,
The EE did indeed follow the 120% rule and he marked it out on the new set of plans that he drew up.
Page 4 of 4 1 2 3 4
