Actually I just found the same web page 5 minutes ago after running a full virus scan to make sure it was not something that came in my mail. I changed changed the settings as instructed and it appears to have fixed the problem on my home PC.
From what I could sort of find from putting my mouse over the message it appeared to be something to do with chat.
Did you just change the background wall paper in the last hour or so, or did I do something else trying to fix my problem?
That's exactly the type of error I had but going into java through the control panel settings and changing the security level back to medium from the "recommended" level seems to have fixed the popup on every page.
I was also not able to grab a screen shot as I wanted to post on earlier.
It could be the chatroom counter. If it's going to be an issue going forward maybe I'll just remove it.
Yes, I did just chane the default Background here to a Valentines Day theme ... Not too crazy about it.
Got to love technology, I liked it better when I had to deal with punch cards in school.
It was also effecting the java test page on Java.com and they did not have any information on the changing of the security levels on their tip page to get it to run clean.
