1 members (gfretwell), 1,593 guests, and 7 robots.
Page 11 of 13 1 2 … 9 10 11 12 13
harold endean #208837 02/14/13 09:54 PM
I found something that may explain what is going on with the Run this application message:
https://service.parachat.com/knowle...n-this-application-security-warning.html
There is also a video version:
http://service.parachat.com/knowled...Do-you-want-to-run-this-application.html
To anyone getting the message .. can you tell me what the name of the Application is on the message?
Admin #208838 02/14/13 10:09 PM
Actually I just found the same web page 5 minutes ago after running a full virus scan to make sure it was not something that came in my mail. I changed changed the settings as instructed and it appears to have fixed the problem on my home PC.
From what I could sort of find from putting my mouse over the message it appeared to be something to do with chat.
Did you just change the background wall paper in the last hour or so, or did I do something else trying to fix my problem? grin
harold endean #208839 02/14/13 10:12 PM
Message says it wants to run an application from electrical-contractor.net/ html 12.
I tried to send a screen shot but could not.
renosteinke #208840 02/14/13 10:12 PM
That's exactly the type of error I had but going into java through the control panel settings and changing the security level back to medium from the "recommended" level seems to have fixed the popup on every page.
I was also not able to grab a screen shot as I wanted to post on earlier.
harold endean #208841 02/14/13 10:13 PM
/208839 html this time
mbhydro #208842 02/14/13 10:16 PM
It could be the chatroom counter. If it's going to be an issue going forward maybe I'll just remove it.
Yes, I did just chane the default Background here to a Valentines Day theme ... Not too crazy about it.
It will be gone by tomorrow smile
renosteinke #208843 02/14/13 10:19 PM
That looks like your previous post #
harold endean #208844 02/14/13 10:22 PM
Got to love technology, I liked it better when I had to deal with punch cards in school.
It was also effecting the java test page on Java.com and they did not have any information on the changing of the security levels on their tip page to get it to run clean.
harold endean #208858 02/15/13 10:28 PM
Well, tonight ECN is doing just fine. May the gremlins be gone!
harold endean #208861 02/16/13 01:25 PM
This morning everything is running A OK around here.
