0 members (), 224 guests, and 15 robots.
Donovon Offline OP
I should have made it clear that i shut off cir 1 and 4 as soon as I made this discovery on my initial inspection. I had been mapping out the circuits with my dmm when I discovered this issue. I made my own plans to scale on graph paper marking each device and its circuit.
the reason for moving the panel is because the service drop now goes over a 14' span of the roof installed on a 'new' patio. The location chosen is a clear shot. I figure I might as well upgrade the existing 50a panel to 200a so I can include yard accent lighting and power to a workshed in the back. I figure 200a gives room to grow. I want to rewire simply to avoid whatever craziness is up in the crawlspace that i can't see and include a device ground as the current system is hot/neutral 2 wire. I figured it might be easier to run new circuits and cut patches to make runs. That way I just leave the old stuff alone and just have it completely disconnected.
I have been showing my folks this thread and they now agree that I may have had a point.
Donovon Offline OP
LOL, wow. We may be related... My Dad's Uncle is the 'other electrician' in my situation. For some reason he was trying really hard to convince my Dad I don't know wtf I'm saying and everything is ok. He was so adamant I finally had to ask here if I should hang up my hard hat and work at Subway...
