0 members (), 754 guests, and 20 robots.
sparkyinak #208067 12/22/12 08:54 PM
I always understood CEMF and back EMF to be the voltage spike in a circuit that is generated when an inductive coil or winding is opened and the field collapses. It is of opposite (counter) polarity of the applied voltage.
sparkyinak #208068 12/22/12 10:22 PM
twh....
That was my first take...
Until mention of track lighting.
Now, having re-read the OP for a third time:
Question: Is this a three-phase circuit?
Did you have the amp reading taken simultaneously?
( Current flow can easily change by 0.15 A over time, as the load heats up and resistance rises. )
Is your amp-meter as sophisticated as a T5-600/T5-1000 by Fluke?
In which case, exactly where and how a conductor is clamped can shift the apparent amperage drawn by such a trivial amount.
What kind of absolute amperage reading were you pulling?
Tesla
sparkyinak #208069 12/22/12 10:46 PM
If I saw .15 a I would start looking for a leaky ballast or something. The same kind of thing that trips GFCIs
