0 members (), 145 guests, and 8 robots.
#205875 04/17/12 11:04 AM
Has anyone seen that Southwire is coming out with a new app for May 2012. It will help for conduit fill, voltage drop, commercial catalogs, conversion calculators, & cable pulls.
Latest Labor & Material Cost Estimating Guides
Latest Labor and Material Cost Estimating Guides
mikethebull #205878 04/17/12 11:54 PM
Sounds interesting!
mikethebull #205985 05/06/12 01:07 AM
That's nothing..
Take a look at their 'home-runs' in-a-drum!
Instead of independent colored spools, they've come out with an entire drum with co-ordinated colors in #10 THWN-2, and such, so that you can pull under slab home runs forever without playing with spools.
It is sure to eliminate a lot of 'tails.'
[ If you shift from 500' spools to 2,500' spools your tails drop by 80%; with this drum approach it's like having a spool 10,000 or more feet long.]
These drums are so heavy that they need a special hand truck -- duly provided by Maxxis.
Check out Electrical Contractor magazine.
Tesla
