0 members (), 749 guests, and 48 robots.
K
KJay Offline OP
I just came across these 4-inch RC remodel cans from WAC. They are LED and apparently IC rated, which makes them the first 4-inch IC rated remodel can I’ve ever seen. Anyone installed any of these yet? If so, how is the quality of light produced by the LED’s?
WAC HR-LED418-RIC
Instruction Sheet
Kjay:
I can't seem to open the 'Instruction sheet' here at the office, nor could I open the spec from the WAC site.
I don't see any mention of UL or ??, are they approved/listed?
K
KJay Offline OP
Yes, the spec sheet says UL and CUL listed. They also say they have dimming drivers with thermal protection.
What’s odd is that the product info page says to maintain 3-inch clearance from insulation for their Non-IC model, but then the spec sheet says that even the Non-IC model can also be completely covered with insulation, so I guess other than having the IC marking as required to comply with 410.116, it seems the actual IC rating may be more of a formality in this case.
Spec Sheet
Kjay:
Thanks. I opened the links at home.
Have to check on $$ at local WAC dealer(s). Hopefully, they have a display up & running.
