0 members (), 625 guests, and 23 robots.
Page 2 of 4 1 2 3 4
fishingmaniac,
If a re-boot doesn't solve this, here are a few thoughts that may help.
Firefox 3.6+ will not work correctly with any less than Java version 6 update 10.
I seem to remember having a similar problem when I upgraded my browser to FF 3.6.
Now, what I suggest you do is manually remove any trace of Java from your computer, via Add/Remove Programs (or whatever your operating system calls this application, in the Control Panel).
When you update or upgrade Java, the installer that comes with the newer version will not by default remove the older version(s). crazy
From there, I suggest you download and install the latest version of Java, which you can find on this page.
One other thing, make sure that you have Java enabled in Firefox, you can check this by clicking on Tools > Add-Ons, the Add-Ons window will open, click on the Java listings, if the "button" to the right of the listing says Enable, it means that Java is disabled, click this to enable Java.
If this doesn't solve the problem, let me know.
That's interesting. I am running Java 1.4.2 for another application. The only thing I have a problem with in Firefox is chat. It used to work a while ago.
Greg,
Software gets updated every now and then.
To use the chat thing here you need the latest version, regardless of your penny farthing model Java.
My problem is I have a piece of software I use all the time that won't work with the new Java. The software that moves shows back and forth from my DVR to the PC.
You folks hear enough from me anyway wink
F
Uninstalled all JAVA and reinstalled latest (I had latest before uninstall) and poof! Problem gone. Thanks!
F
Now lets see. Here in Massachusetts, I know, I know, it is what it is...
Anyway, trying to make a good rule of thumb for arcfault vs GFCI requirements in residential dwellings, such as:
GFCI:
1) 2 20A GFCI circuits in kitchens
2) at least 1 20A GFCI available in each bathroom
3) unfinished basement receptacles
4) all garage receptacles
5) all outdoor receptacles
AFCI:
Everywhere else except:
unfinished basement receptacles (GFCI there)
what about these:
range? 120 or 240?
refrigerator?
furnace?
AC condensor?
sewage ejector pump?
GFCI:
AFCI:
what about these:
range? 120 or 240?
refrigerator?
furnace?
AC condensor?
IMHO No to all
None of these are usually in one of the 210.12 rooms
If you want to continue this, let's start it up over in the "NEC" topic. That is where we have these kinds of conversations. and more people will find it.
new contractor here....love the sight, lots of great information.....
Candyman, lots of smart guys here, this is the place to come to for educational reading. I look at the new posts every day when I get in from work.
Jimmy
Candyman:
Welcome to ECN Forums, from one of the 'Jersey Guys'
Jump in anytime!
Page 2 of 4 1 2 3 4
