0 members (), 392 guests, and 30 robots.
Page 3 of 3 1 2 3
Also not Stinger leg related but deals with building a better idiot. I was asked to have a 240 VAC receptacle installed for a copier. The copier arrived and as the prongs on the cord would not fit in the copier receptacle, they took a pair of pliers and twisted the the one prong on the cord 90 degrees so it would fit and promptly destroyed the $2000 copier. Called me up and asked me why it didn't work.
Idiots!
I once hooked up a 3 ph range to a wild leg all 3 leads had no markings or you might say phase identification but i happened to hook the clock to the wild leg worked great for about a minute,the manufacturer replaced the unit w/ a new one and the leads were marked on that one
oo oo that smell can't you smell that smell
Also not a stinger leg story but came across a MIL unit that the owners wanted to replace the 2X4 recessed troffers that were in the kitchen & living rooms with ceiling fans, they had demoed the ceiling & done some demo of the troffers, there was one "minor" problem the fixtures were 277V & they did it hot.
Backstory on this is the building the MIL unit was in was a "AG shop" w/ a 200A 480Y/277V service w/ a 15 KVA tranny supplying 120/240V & part of the building had a mother in-law(MIL) unit attached & it was all bootleg. BTW, ag services were exempt from inspection until a few years ago.
Panels
[Linked Image from i197.photobucket.com]
240V panel closeup.
How many violations can you find?
Pump & NEMA 1 480V disco.
Page 3 of 3 1 2 3
