If you install or maintain Siemens PLCs and related hardware, you might want to look at this, then check your programs for unwanted modifications:
http://www.computerworld.com/s/article/9185419/Siemens_Stuxnet_worm_hit_industrial_systems
From the report it looked like Iran was the target?
A programming attack on an industrial control system could destroy a Nuke power plant or set off a chemical explsion as 2 examples. There are so many malicious things you can do if you could get control of industrial control systems.
