Violation?
by renosteinke - 01/27/23 09:52 PM
Does NEC 551.71 (F) apply to dwellings?
by BigB - 01/20/23 10:46 AM
Power submeter connections
by HotLine1 - 01/19/23 09:09 AM
AFDD's coming to the UK
by Texas_Ranger - 01/17/23 07:22 PM
Burger King crown sillyness
by wa2ise, December 11
240/208 to a house
240/208 to a house
by wa2ise, October 9
0 members (), 116 guests, and 11 robots.
#195712 08/19/10 09:59 AM
The engineering company where I work has asked for input to improve safety within the facility. I submitted an issue informing them that our kitchen does not have GFCI’s on the outlets. They informed me that since this room does not have a sink it is not classified as a “kitchen” per the NEC. Yet, above the outlets is a plumbed coffee machine and a plumbed bottleless water dispenser which are next to a toaster and microwave. A refrigerator is also located in the small room.
Are there any requirements in the NEC to require GFCI’s in such areas (ie- with plumbed water)? Isn’t the definition of a kitchen in the NEC to exclude snack rooms with vending machines but not areas with plumbed water?
Any comments are welcome.
2020 NEC & Related Reference & Study Guides
Pass Your Exam the FIRST TIME with these Exam Prep Combos:
>> Master Electrician Exam Prep     >> JourneyMan Electrician Exam Prep
If the company has been tasked to improve safety you could suggest that the GFIs be installed based on the breakroom having similar activities happening on the counter. I thought there had been some discusion about a similar topic before. Maybe I am just remembering the change that requires the GFIs in kitchens in other than dwelling units.
Engineer:
Welcome to ECN Forums!
Keep in mind that the NEC is not a design tool.
From a safety related study, the design professional has the ability to exceed the requirements within the NEC regarding GFI protection. I guess, if one wanted to, one could install AFCI protection on 15/20 amp, 120 volt receptacles within office areas.
My point, if safety is the concern, by all means install the GFI receptacles; you may want 'spec' grade devices also.
Tools for Electricians
2023 NEC Now Available!
2020 Master Electrician Exam Preparation Combos
2020 NEC Electrician
Exam Prep Combos:
Master / Journeyman
CDS
CDS
Nicholson Ga
BigB 8
triple 3
302,664 Are you busy
231,943 Re: Forum
216,602 Need opinion
