0 members (), 164 guests, and 10 robots.
Page 4 of 5 1 2 3 4 5
gfretwell #195038 07/07/10 10:11 AM
Greg,
I remember that old silver asphalt wire from years ago. They use to use it all around this area in the 60's. I believe it also had a smaller grounding wire in it too.
When they use to make AL wires, they use to have black insulation on that wire.
Lastly, once when I first started in business, I found a job where the HO did all of his own wiring. I think I saw every kind of wire connecting everything together, Black wire, asphalt, zip cord, AC, extension cord wiring, etc. Plus that was just in one room behind the dry wall! I told the GC of the job that I couldn't guarantee any wiring unless the drywall was removed. So he had to remove most of it in order to be sure that the wiring was safe.
Workgear for Electricians
sadly, that's been my existence for 1/4 century Harold
imho, Rod Sterling could have written an episode on it...
[Linked Image from jakestakeonsports.com]
the strange phenomenon of a garden varity electrician, trapped in a mobius logic strip of vintage wiring, unable to escape the daily explanations of it.........
~S~
sparky #195044 07/07/10 10:42 PM
~s~:
"priceless"!!!!
HotLine1 #195050 07/08/10 01:30 AM
My childhood home (brand-new in 1967) was wired with that silver-asphalt "Romex" from top to bottom in Fayetteville, NC. Although I was only seven years old, I remember it well. Even the 6/3 for the range had this same form of jacket (no ground wire of course). I was just a very inquisitive kid, what can I say?
My parent's house in Virginia that was built in 1974 still had some 4/3 SEU cable feeding the furnace that had a similar jacket. The second 4/3 circuit was "that modern stuff". Wow, two 70 amp copper circuits feeding a straight-electric forced air furnace. Can you imagine that these days?
---Ed---
EV607797 #195051 07/08/10 03:51 AM
YMMV with ground wires in the paper Romex. This house (SW Fl) has the smaller ground (1963) and the house I grew up in (DC area) had the same reduced ground in paper RX built in 1953. It was only connected to the box. NEMA 1-15 receptacles throughout.
If you plugged in the 5-15 adapter and hooked up the ground wire you did have a ground.
gfretwell #195053 07/08/10 07:40 AM
that makes me wonder, is there any sort of 'history of wire' (for lack of better terminology) that would forward details .....?
~S~
sparky #195057 07/08/10 02:27 PM
Sounds like something Mike Holt may have.
gfretwell #195102 07/12/10 09:32 AM
Greg,
I found this like:
http://www.codecheck.com/cc/wiring_history.htm#nmnoground
I didn't read it yet, when I am done here I will go back to it. And as we all know, if it is on the Internet! It must be true! smile Everything with a grain of salt.
They even have Joe's "original NEC" on that page.
It looks reasonable. I know they were using grounded RX in DC in 54 as the article says.
gfretwell #195110 07/12/10 09:13 PM
Talk about a trip down memory lane...Joe T...Dave S (aka 'Davie' and a few other handles. Only place I read Dave S is his monthly resi articles in EC Mag.
Joe T., where are you??
