Transformers & Feeders:3P 4Wire Closed Delta
Five Drawings of Transformer Setups (Connection Schemes);
Primary and Secondary Feeders, Plus OCPDs and Panelboards for:
3 Phase 4 Wire Closed Delta Transformers
(Two Voltage SDS)
NOTE: Click on Image to view Full-Sized Image
Drawing 3PH4W-CD1: 480V x 120/240V 3 Phase 4 Wire Closed Delta - Center Tap Grounded Neutral
(Max. Voltage To Ground = 200V, Nominal = 120V; With Grounded Conductor)
Single Panelboard fed by Secondary Feeders.
![[Linked Image]](https://www.electrical-contractor.net/forums/gallery/24/medium/245.png)
Drawing 3PH4W-CD2: 480V x 120/240V 3 Phase 4 Wire Closed Delta - Center Tap Grounded Neutral
Single Panelboard fed by Secondary Feeders, Additional Panelboard "Subfed".
![[Linked Image]](https://www.electrical-contractor.net/forums/gallery/24/medium/246.png)
Drawing 3PH4W-CD3: 480V x 120/240V 3 Phase 4 Wire Closed Delta - Center Tap Grounded Neutral
(Max. Voltage To Ground = 200V, Nominal = 120V;, With Grounded Conductor)
Two Panelboards fed via Tapped Feeder.
![[Linked Image]](https://www.electrical-contractor.net/forums/gallery/24/medium/247.png)
Drawing 3PH4W-CD4: 480V x 120/240V 3 Phase 4 Wire Closed Delta - Center Tap Grounded Neutral
Two separate Panelboards fed by Secondary Feeders- each set derived from "X" Terminals.
![[Linked Image]](https://www.electrical-contractor.net/forums/gallery/24/medium/243.png)
Drawing 3PH4W-CD5: 480V x 120/240V 3 Phase 4 Wire Closed Delta - Center Tap Grounded Neutral
Distribution Panel fed by Secondary Feeders.
![[Linked Image]](https://www.electrical-contractor.net/forums/gallery/24/medium/244.png)
Text #3: Two Voltage SDS - Primary & Secondary OCPDs
(Click on Image to view Full-Sized Image)
![[Linked Image]](https://www.electrical-contractor.net/forums/gallery/24/medium/216.png)
