0 members (), 1,035 guests, and 11 robots.
#110335 03/30/06 08:26 AM
From Scameron81
I got a call from a lady who wanted to see about upgrading her service.
When I walked into the basement needless to say I was a little surprised. I told her that the whole house needs to be redone because it is old and dangerous wiring. This looks like one of those jobs where you start with the panel and before you know it you end up rewiring the whole house.
The house is fed with a 50A 240 single phase service. There are 3 subpanels coming off this main panel. I don't know who installed the "new" main panel, but I am guessing it probably only had a tailight warranty.
Scameron81
#110336 03/30/06 07:11 PM
electure , the old meter is a GE I-14 Ait is usually rated at 15 amps.maybe 25 at most. is that 3 phase panel got the neutral going through a fuse?
#110337 03/31/06 10:18 AM
Wow! I'm at loss of words here!
Still, they bothered to use a box for splicing the K&T to the THHN!
What suprises me most is the fact the PoCo never swapped out the meter! Here they are swapped every 15 years for recalibration!
#110338 04/01/06 04:19 PM
3 subpanels on a 50A service??? Doesn't make alot of sense... The meter looks to be literally around 100 years old.. Fused neutral? [Linked Image] Scameron, is this in CA???
I'm curious where she got the idea to upgrade her service after someone installed the new panels [Linked Image] (I'm guessing the handyman would only mess with what he could shut off, (which in itself is bittersweet).. He took the money for the subpanels and probably muttered on his way out the door, "Oh you need an electrician to change the rest")
#110339 04/03/06 09:25 AM
Gotta love that 3/4" compression connector used to 'protect' the knob & tube conductor.
The old school meter is also pretty priceless.
My god is that a meter in the middle on the first picture.
Luke McCoy The NEC Crazy Boy
That's what it is, Luke.
What I would like to know is, what is that wierd looking black blob at the top of the panel?
A joint of some kind?
That's an interesting sort of a termination method on the meter tails feeding that new panel. crazy
I also get the feeling this is 3Ø, after all, who in their right mind would fuse a neutral?
Thanks
Trumpy:
I'll venture a guess for the black blob....
What I've come accross over the years, it may be a split bolt 'bug' wrapped in many layers of rubber/ friction tape and overwrapped in vinyl.
Basically, something you would not want to 'take apart'
It may have been a 'more is better' thought.
Looks like a fused neutral. If you look at the wires under the meter the two hots come up into the meter and the neutral appears to pass by into the panel. It even sort of still looks white.
