0 members (), 1,212 guests, and 10 robots.
groupies???
Hmmmmmm OK...
When I have to "tap" (misused term here) into an existing NM cable, I always have to use two Jct boxes a couple feet apart with a jumper in between, in order to have enough wire length to work with. Just another case where it takes me twice the material as my competitors because I won't go below code... (competitors meaning local EC's and "the like")
SvenNYC: Home Improvement in Da Hood!
LOL! Too funny!
Mike, Hee hee! That tester could also be known as a "wiggly" (your helper wiggles when he is part of the hot circuit!)
Ya, Steve, and Booze too!
[This message has been edited by sparky66wv (edited 12-09-2002).]
-Virgil
5 Star Inspections
Member IAEI
Is the recepticle installed under the eaves reqired to be GFPE protected and not GFCI? Does this not also apply to recepticles servicing heat trace? My thought would be who would be the one to climb the latter to reset the GFCI, or for that matter, climb in the attic to reset the GFCI? I would at least run a new circuit down to the service. Some lighting diplays can be very eleborate.
Merry CHRISTmas
Mark
