1 members (Scott35), 53 guests, and 10 robots.
Redsy Offline OP
A customer has a high-end range hood with a variable speed motor.
The controls for the fan and lights are difficult for his wife and daughter to reach, so he wants to add a speed control on the wall.
The controls for the existing fan are electronic, and I don't believe that putting a fan control ahead of them (or after them)is a good idea.
It would be (2) controllers wired in series.
Any thoughts?
Thanks,
John:
Check with the mfg first. Personally...I would not touch it. Could turn into you buying a hood you might not like!
If this is a brand new install or the hood still has a factory warranty on it I would not touch it either.. If the hood is out of factory warranty or it was for myself say, I would bypass the existing controls for both the light and fan, and then use a standard speed control for the fan and a separate switch or even a dimmer for the light.
Redsy Offline OP
Thanks guys!
It seems we are all on the same page.
