0 members (), 174 guests, and 29 robots.
This conduit run is from a dwelling to a detached structure on the same property with the dwelling at a lower grade. There is alot of ground water present on the lot. The conduit is picking up water every time it rains hard.
I did a google search and found this product...
http://www.nettechdi.com/polywater/fst_foam_duct_sealant.htm
This is what I had in mind, just not sure if it will work.
shortcircuit
I wouldn't order anything from them..... the reason?
The "kit" seems to be a far cry from sealant
Product Description:
PN5CJ CRLN, 2 DB120 22 1/2D X 18R SWP. 2" 22-1/2" degree x 18" radius elbow.
Your Price: $ 9.150 ea
The "tool" costs $57 for a caulking gun
Product Description
FST-TOOL POLYWATER, APPLICATOR TOOL FOR 2 PART SEALANT KIT, RATCHETING STYLE CAULK GUN
Your Price: $ 57.255 EA
Tom Offline
Unless you live in a desert, underground conduits will eventually fill with water due to condensation. The best solution IMO is the previously posted suggestion of bringing all penetrations into the house above grade level.
