AE-Gifts, Affordable Everyday
0 members (), 352 guests, and 8 robots.
Page 1 of 4 1 2 3 4
#179312 07/06/08 05:47 PM
Just about every "alphabet" group you can think of recently took part in a survey of older homes, and their electrical systems.
30 homes, slated for demolition, were examined from service drop to outlet. Components were sent to a lab for further examination and testing.
With the NFPA asserting over 24,000 household fires - and a disproportionate share of these being in homes older than 40 years - are caused by the electrical system, what causes do you think the study found?
(I'm cheating ... I have a preliminary draft of the report ... I just want to see what "conventional wisdom" thinks laugh )
renosteinke #179313 07/06/08 05:48 PM
I suspect homeowner modifications will rank high on this list. As will deteriorating insulation. And probably a certain amount of damage from rodents, birds, and the like.
I expect there will also be assorted problems at receptacles.
twh Offline
Thirty homes is a small sample considering the number of homes that don't burn down. I would guess that very few had electrical problems.
twh #179315 07/06/08 06:49 PM
I think most problems are on the load side of the outlets.
gfretwell #179316 07/06/08 09:27 PM
I have to agree with Greg that what is plugged-in would be a primary cause. A lot used to be attributed to 'overfusing', in the days (and areas) that edison base fuses were prevelant, of which I saw my share.
I remember the guy at a local hardware store commenting something to the effect of....'we used to sell a lot of 15 & 20 amp fuses; but since a lot of people started buying the 30's, sales have slowed way down'.
Fire cause determined to be caused by 'electrical' seems to be vague; it should be broken out into utilization equipment and premises wiring.
HotLine1 #179317 07/06/08 10:04 PM
I'd say improper use of extension cords would be #1 and fuse tampering would be #2. I get so mad when they report a fire on TV news and cite the cause as being electrical. Later they report that three portable heaters were plugged into a 100' 16/3 extension cord. That isn't an electrical fire.....That is a stupidity fire.
Something tells me that aluminum wiring is going to get thrown under the bus on this report too.
---Ed---
EV607797 #179318 07/06/08 10:10 PM
Actually ... aluminum missed the bus - this time! The houses all pre-dated the aluminum wiring craze.
EV607797 #179319 07/07/08 12:16 AM
I'm right there with you on this!!!
But I say "Fire alarm" and my insurance rates (liability) go right thru the roof !!!! I prevent this crap!!! (Or at least detect it)
But I digress.. I will go with poor/loose connections at the devices. Wich coincides with the overloading of appliances. (whoa.. Both ends to the middle. Smooth.. No?):)
leland #179321 07/07/08 10:02 AM
Z
As stated above, I'm sure deterioration from misuse on the load side is gonna be right up there.
Also, I would guess that, if the homes were old enough, they probably found quite a few exposed wire joints. I've found that the old solder-and-wrap method of wire joining, although good from an electrical conduction standpoint, suffer from deterioration of the wrapping materials and don't handle maintenance and handling too well. Also, a few times being pulled in and out of the junction box for add-ons and repairs tends to break up the old cloth insulation pretty badly too.
So, I would guess that they would classify this as "post-build maintenance damage", or something like that.
Induced voltage is also prevalent in these old installations.
Improperly bonded and altogether loss of the grounding system also comes to mind.
Zapped #179322 07/07/08 10:04 AM
Z
BTW, what a great idea for a study... I'm sure there was quite a bit to learn from this. I would have loved to have been on that archeological dig.
Page 1 of 4 1 2 3 4
