0 members (), 246 guests, and 22 robots.
Oh, you were serious about using solar. If the device gets structually attached or anchored, then it falls under the NEC.
Walus, I understand you concern of safety. What I am saying is you have a choice of GFCI protection or not. If you are really concern, you can put a lockable cover like a weatherproof while in use cover and put a paddle lock on it if you do not want to use a GFCI device and prevent others to use it. If you are installing for some one else. Tell them the pros and cons and let them decide.
Workgear for Electricians
Huh? There is a whole section on photovoltaic in the NEC.
