0 members (), 1,370 guests, and 10 robots.
Gypsum is essentially just rock, and it comes from the ground, so bonding directly to is like this is clearly just as effective as a full-up grounding rod.
What is the story behind this?
Steve:
I hope that's a joke??
Judd:
So the unit has no EGC?
It was attached to the wall but now attached to the frame.
The lesson is in the struggle, not the victory.
Can you say
HANDY MAN!!!
wow, i didn't think that drywall was conductive enough to ground an AC unit...
-Joe
“then we'll glue em' then screw em'”
-Tom Silva
TOH
BTW, in case anyone didn't catch it, my quip was a joke!
... it's the lead paint that provides the grounding. crazy
sbi Offline
good one
when in doubt jump it out
I happily work for slumlords
Originally Posted by pauluk
What are we looking at here? Is that a heater or A/C unit with the cover removed?
It looks like a3-wire supply cord. Is that green wire just the EGC from the cord, or is it secured to the appliance frame?
Does it matter? (grounding/bonding or anything else).
"It all depends, is that a sheet metal screw? You need to bond drywall with a drywall screw."
Too funny!
"and you must keep the drywall moist"
Now my sides hurt!!!!! smile
