0 members (), 435 guests, and 12 robots.
Page 3 of 3 1 2 3
Admin #164993 06/16/07 01:42 AM
Me and a few friends got a few minutes of laughs out of this one. If I recall correctly, most communication cable insulation is only rated for around 60V or so. (I know it's too thin for 120V!)
Now that's what I improvising, I'm amazed that CAT 3 cable hasn't fried yet, that light bulb will make a nice mess if/when those ropes break.
I have a sense of adventure, I just keep it leashed with common sense.
Actually, communications cable is rated for (i think) 150v). POTS ring voltage is 90-100v at ~20hz.
techie #176646 04/08/08 02:30 PM
24 ga paralleled is the same as 21 ga, so that's about 13 ohm/1000ft. If that run is 20' (up and back down again), that wire presents a resistance of 0.26 ohms. If that's a 240VA 120V load that's 2A of current in the wire, power lost in the wire is P=I^2*R, or about 1W. Despite how bad the installation is, that wire wouldn't even get warm. I still don't approve, and I'm sure this much thought didn't go into this installation. wink
Page 3 of 3 1 2 3
