0 members (), 740 guests, and 13 robots.
#174485 02/05/08 09:25 PM
Redsy Offline OP
I'm looking for the best method to install receptacles in the middle of a drop ceiling tile.
Caddy & B-Line have brackets to support 4" boxes, but if I install a tile-ring and receptacle, I think the force from inserting the plug will push the whole thing (t-grid and all) upward, resulting in a sloppy installation.
What do you all do?
Thanks
Go to HD or Lowes, get a 24 X 8 Laminated shelf. mount box in shelf, cut 8" off tile, install a cross tee. a few screws thru the frame holds it all in place.
Use a self taping screw throught the bracket to the grid. I don't know if it will work with the Caddy 512, as they may be hardened.
Ob
I usually use 7/8" strut to mount the box on and secured the strut to the structure with 1/4" threaded rod.
Roger
Redsy:
I have used the Caddy with 1/4 rod to prevent upward movement when plugging in.
Ceiling grid is getting flimsier by the week.
I cut a piece of 3/8 plywood to the size of the ceiling tile. I put it right on top of the ceiling tile and use a 1" plaster ring on a 4" box supported by a Caddy 512. The plywood lends weight and stiffness to the whole thing. Keep in mind that ceiling plugs usually get 1 item plugged in and it stays there. They are rarely used as true convenience receps.
Redsy Offline OP
Thanks for all your ideas guys!
I wondered if the grid was heavy enough to prevent upward movement.
I appreciate your input.
