1 members (dsk), 1,418 guests, and 21 robots.
Originally Posted by pauluk
Me and my aunt in NJ are having a "competition," who can put up the most lights...
Ah, so you're the ones responsible for the latest power crisis in the States! wink
grin
YUP, They all worked when I took them down. Now over 2/3ds DON"T!! She's Bi***n And I aswell. Over $200 last year for lights.
I can't beleive anyone would try this more than once!!!!!!!!
You guys are outa' your minds!!!!
I'm moving to SO.Cal. No Christmass in warm climates, Right !!!!? (PLEASE SAY YES!!!!!)
PS: WHO WAS THE GENIUS WHO DECIDEd THEY SHOULD BE IN SERIES!!!!!!!!!!!!!!!
ARRRRRRRRRRRRRRRRRRRRGGGGGGGGGGGG.Just a tad miffed.:)
Here is a start on my lighting for the season. The larger C9 lamps are removable from the string so i can make my own Pattern of lamp placement
[Linked Image from electricalphotos.com]
And then it snowed
e57 Offline
This year I will be doing a "less is more" home-made DIY job with prismatic - lo-tech gobo and wash of the whole front of the house - I started today.... I'll post pic's as they come....
e57 Offline
This is my snow flake light - I cut a piece if 24ga steel into a snow flake and mounted it it 3/4" Emt with few spot welds. The lighting effect is from two MR-16's (w/ a red and a green dicro filter for each) from two simular but slightly different angles through 2" EMT to give it a clean spot - The spot shows as yellow - but the shadows of each snow flake show as red and green.
There's this "series/parallel" flashing and variable brightness Xmas light scheme we've done for years:
[Linked Image from pw2.netcom.com]
In the schematic diagram under the tree, the black bulbs indicate a string that had its flasher bulb go open circuit for the moment. You rig up a violation like this to make it work: [Linked Image from pw2.netcom.com]
http://pw2.netcom.com/~wa2ise/radios/xmassp.html for more details
Cool, e57! If you add a third light, with a blue filter, you can have a white background, and red, green, blue, cyan, yellow and purple pieces of snowflake. Arrange the lights in a triangle pattern.
Thet looks great. How would you get "SEA FOAM GREEN"?
AAARRRRRRRRRGGGGGGGGGGGGGGGGGGGGG!!!!!!!!!
Your' still outa your minds.:)
Hello everyone,
Thanks for bringing this thread to life electure. smile
I just started putting up lights the other day. I have 400+ C9 mulitcolored lights to hang, and some other 'stuff'..I will surely take some pics and post them.
Ya'll have a classic day and I'll be in touch. wink
Luke Clarke
Electrical Planner for TVA.
e57 Offline
Hmmmmm, New Years I just might add that....
