Fenwall,pendant heats:
We use a large solder iron,remove the tip and it slides right over the heat, works great.
On the HIDs',the copper line systems, we use the hot water trick,I've found no better way.This can be tricky on top of a ladder with a pot of very hot water.
These are still in use in alot of our chemical/paint customers places.
