1,544
6
The worst one I saw was a homeowner who said as we were walking up "I don't think you can help me", opened his Bilco doors and water was coming out, he had about 7' of water in the basement. The other bad ones had about 3'. I believe you could've helped him JCooper. If you had enough sections of 4" hard suction hose, you probably could have pumped water out of people's basements with your deptartments fire truck.
Luke Clarke Electrical Planner for TVA.
Seriously, this is a terrible ordeal for all involved. I hope everyone affected can dry out asap, and recover.
Luke, I believe our FD does or did do exactly that. -Will
I saw the picture of route 18 underwater on the cover of the Ledger before. Holy... that definitely didn't happen after Floyd!
Posts: 793 Likes: 3
I liked the ones who were in a panic over an inch or two. As we were walking into houses we were asking people how many feet of water they had, anything under a foot, call a plumber in the morning, I had about an inch in my basement. No real damage to anything, just some soaked cardboard boxes. I had a small water pump and a wet/dry vac, and the sump pump was working overtime. I didn't even think to call the fire dept for this. Only reason I even had water was that the power wnt down for 3 hours, and the sump pump couldn't work. Turns out my local substation flooded...
My department didn't do any pumping, another department in our district has four portable pumps, each one moves about 120 gpm, there were some houses where they set up two and it took two hours to pump them out. We were trying to figure out how to hook some hard suction up to our brush truck, that moves around 200gpm. If we could get enough hard suction, and get a prime going, and hooked up to our engine we would be moving 1500gpm, dry in no time!
Just be careful you don't shred the crap out of your truck when debris passes through the pump.
Just be careful you don't shred the crap out of your truck when debris passes through the pump. No worries there, hard suction hose comes with strainer/float devices to circumvent those type of anomalies from happening.
It isn't the pump you have to worry about, it is the basement. We had several basements collapse when being pumped because the water pressure in the ground was greater than the strength of the basement walls. Alan--
Another department had that problem, one basement only had a few inches of water, but a four foot section collapsed due to the outside water pressure.
