Page 7 of 9 1 2 3 4 5 6 7 8 9
(chucks an ROP under Virgil's bed..)
Go for it, i'm not sure where or how, perhaps via exception to current rulings???
Go to www.ilsco.com and do a search on grounding and look at this bonding connector.GRM GRD CONNECTOR CU/ALUM.
It comes with a 1/4 or 5/16 stud and I suspect that this may be the purpose of the 1/4" ko.
I have had to use this fitting on larger services in the CT can to satisfy poco.
GRM
GRD CONNECTOR AL/CU
[This message has been edited by txsparky (edited 09-20-2002).]
Donnie
Gwz Offline
I rather imagine that about a year from now we'll have a CMP comment.
Here is a reply from Mark Ode from UL
A weep hole or drain hole, usually located in each corner of the
enclosure must be left open and not used for a No. 4 grounding electrode
conductor, even though it fits extremely well, since the purpose of the
holes are to ensure that any water that may enter the enclosure for any
reason has the ability to drain out of the enclosure. By inserting
something into these holes and encumbering drainage, you may adversely
affect the operation of the equipment.
There are some panels that have the corner drain holes with an additional
small knockout inside of a larger knockout where either the small knockout
can be removed and a No. 4 inserted into the hole or the larger knockout
can be removed with a connector installed and then the No. 4 inserted into
the connector and tightened down.
These knockouts were installed so that
the user would not hopefully feel the need to use the weep holes for this
purpose.
...where either the small knockout can be removed and a No. 4 inserted into the hole or the larger knockout can be removed with a connector installed and then the No. 4 inserted into the connector and tightened down...
The choice seems to be evident.
What about the lone 1/4" KO without an outer 1/2" KO around it?
[This message has been edited by sparky66wv (edited 09-24-2002).]
-Virgil
5 Star Inspections
Member IAEI
But are we back at what connector is listed for a bare #4?
Steve
Yep, round and round we go!
Don'cha just love code loops!
-Virgil
5 Star Inspections
Member IAEI
Just use the 1/4" ko and you don't need a connector per the UL response.
Don
But Don, they're only talking about the KO that is inside a 1/2" KO...
In other words, the one in my pix is left out of the options!
-Virgil
5 Star Inspections
Member IAEI
Sparky,
It is not a weep hole and if a 1/4" KO inside of a larger KO doesn't require a connector for the GEC, then why should a 1/4" KO by itself require a connector?
Don
