1 members (DE_Contractor), 153 guests, and 3 robots.
#128302 02/01/03 03:50 PM
Steve T Offline OP
Thanks, I think I get the jist.
Are there any books anyone is aware of that might explain in more detail phase converters?
Workgear for Electricians
#128303 02/01/03 10:33 PM
They get discussed from a d-i-y point of view sporadically at rec.crafts.metalworking and rec.woodworking
If you don't have a usenet account set up, then search in "Google Groups."
#128304 02/07/03 02:34 PM
F
hey hey you guys there is the other companine they do make phase conveter also it called ronk conveter i belive if i rember the web address is www.ronk.com but if i did give you wrong one please do let me know i used the ronk they make few diffrent versions of phase converts both satic and rotary version i allready deal both of it it have good and bad each one if need more info let me know i will try to explain more about
merci marc [Linked Image]
#128305 02/08/03 09:19 PM
Steve T;
I am unsure of any books to suggest. Maybe try your local Library, or do a Google Search.
I can draw some simple schematics, but at this time uploading graphics is N/A (some problems need to be fixed with the ECN server).
Once this is resolved, I can post away again!!!
Scott35 S.E.T.
02.08.03 17:20:00
#128306 02/08/03 10:43 PM
Steve T Offline OP
Thanks guys
#128307 02/09/03 12:27 AM
For Ω, type ampersand-pound-8486-semicolon. Here is an example, but type it without the spaces to get it to work:
& # 8 4 8 6 ;
For &#8730, type ampersand-pound-8730-semicolon. Here is an example, but type it without the spaces to get it to work:
& # 8 7 3 0 ;
[This message has been edited by ThinkGood (edited 02-08-2003).]
#128308 03/08/05 05:38 PM
I hope I can ressurect this old thread.
In followup to:
"Steve, instead of visualizing it as a wye case, consider it more like a 4-wire-delta arrangement. There will still be ~240V between L1-L2 [and about ~120V L1-N and L2-N.] For the “manufactured” T3, there will be ROUGHLY 240V L1-T3, T3-L2 and ROUGHLY 208V T3-N, but don’t expect nice, even, symmetrical measurements like you’d see with conventional utility-type delta transformer service."
Since a rotary phase converter can serve multiple loads, I have a question regarding the distribution of its output with a 3 phase panel. Is it legal by code to treat this as a 4 wire Delta 240/120V system as outlined above. Can the neutral be brought along from the single phase supply to serve 120V single phase loads at the machine, motor controls in particular.
#128309 03/11/05 12:21 AM
Steve T Offline OP
It's nice to see a topic be resurrected two years and one month later to the day.
#128310 01/11/06 06:50 AM
Hi, 2 things to discuss:
1.
1 phase to 3 phase converter. I built one years ago from a 5 HP Heemaf 3Ø motor which I start on 2 Ø with a 125µF capacitor to the 3rd phase to get a phase shift. The motor starts up perfectly, when up to speed a 3 phase 3 x 230 volts is available.
This is perfect to start up any 3 Ø motors up to 3 HP. which don't have to start into a heavy load e.g. lathe etc.
This is done from a 230 V 50 Hz supply via a 16 Amp MCB.
omega symbol. I still like to find the short way of getting it. While typing i like to acces certain symbols without to drop down to other lettertypes etc to get it.
Like i can type now alt+230 and have direct access to µ symbol.
Why is it such a pain with the Omega!!! [Linked Image]
i have goooooogled for it but not really to successfull at this stage.
#128311 01/11/06 06:54 AM
sorry i did forget to add that i automatically switch the capacitor off after about 5 seconds when the mototr is up to speed.
The 3 phase motor appears to be quite happy single phasing and runs a lot smoother than a 1Ø motor (less noisy) OK i know that i have not the full 5 HP available but that doesn't matter. it serves my purpose of a 1Ø to 3Ø supply in my workshop at home.
