0 members (), 1,023 guests, and 14 robots.
#127333 06/02/01 12:36 AM
Phil,
Thanks for the link!!!!
I'll check it out after sending this message!!
Scott SET
Workgear for Electricians
#127334 06/02/01 03:24 PM
sparky Offline OP
whoa,
now that's an intense link!
i think i get the 'lamp-eye-brain' part so far...
#127335 06/02/01 09:39 PM
[Linked Image from manta.ieee.org]
Oh yes! I've been looking for that! [Linked Image]
We're gettin pretty deep in here! [Linked Image]
#127336 06/10/01 06:12 AM
sparkey
I have never run across the term flicker factor before. But have done some power quality analisys. In my research I found a case study on light flicker done by a company that makes power quality analysers.It explains light flicker in a manner that is easy to under stand. You can find this article at http.//dranetz-bmi.com
go to the library, look towards the bottom at case studies. Its labled light flicker in office complex.
#127337 06/10/01 07:50 PM
sparky Offline OP
#127338 06/10/01 09:13 PM
Anonymous
Unregistered
The URL is:
http://dranetz-bmi.com/CaseStudies/CASE25/cstudyflick2.html
Hint: if you use copy and paste to copy the correct URL, you can avoid any typographical errors.
