1 members (Scott35), 420 guests, and 17 robots.
#127260 05/18/01 09:30 PM
Scott35 Online Happy OP
Let's see if this image uploads right, then we can discuss it!!
BTW: It should be a 1 phase 2 wire transformer with split coil primary and secondary. Pri connected in series, Sec connected in parallel.
Scott SET
Scott,
Nice Diagram, you're getting good at that!
Thanks, Bill!!
The problem I was having with the font size is because when I plot stuff from AutoCAD, a font sized as they are in these drawings turns out to be maybe as large as 2" tall on the plan pages!!!
So I was using my preset scaled fonts for AutoCAD, which will plot [print] fonts at 10 to 12 point size on 1/4" = 1'-0" scale drawings.
Needless to say, they sure looked big to me in AutoCAD [just used to it].
Totally different story when they got uploaded!!
Thanks for all the neat stuff and the utility!! Sure makes things easier on my end to edit.
Scott SET
Scott,
OK,
Let me start things off here. What are the key features/benefits and qualities/uses for this type of Transformer?
Great job Scott!
