0 members (), 164 guests, and 10 robots.
Dave,
Does that mean that gound is what you usually talk to on pint sven, once clear of the ative rnway?
Je
e57 Offline
Most runway and taxiway lighting (other than signage) operate by means of series wired current transformers at each light on ungrounded systems, hope you wore gloves....
Anyway, sounds like this place faired well, it's still standing...
I hate when I run out of airspeed, altitude and ideas all at the same time.
TW
JE
Yep THAT ground except where I was it's on pint niner when clear.
When I "firmly" contacted the ground (read: supporting surface) at least I kept flying it till the last bit stopped moveing. Then I ran like HEdouble hockey sticks away as fast as I could. :-)
What is wrong with you guy's, "black to black, white to white, ground not needed". It work's don't it?!
Hank
Landing lights are a great boon. They help to stop you falling down the stairs in the dark.
