0 members (), 373 guests, and 26 robots.
#119620 01/09/05 11:13 PM
Had a service call where customer couldn't make lights work, even though they insisted that they had checked all the breakers.
I found an additional panel located directly behind the customers' own desk, concealed by a painting.
Would you consider the painting to violate working space requirements? What about other methods we've seen people use to hide/camoflage the ugly panel?
- John Steinke
K
kd Offline
The painting is a good idea assuming it is removable. A painting of Benjamin Franklin would be even better.
As I remember, that should be a safe box. [Linked Image]
The world is full of beauty if the heart is full of love
Yes John, I would consider it a work space violation.
Not only that, it's a pretty nasty sort of a trick to go hiding panels like that.
Oh well, your customer paid for that lapse of memory!. [Linked Image]
Mind you, driving nails into a wall above a panel, isn't exactly my idea of a great party trick.
Only if you are climbing behid the painting to work on the panel.
I would consider this not readily accessible.
When you cannot see the workspace, is it a violation of workspace?
Sort of like, does a tree that falls in the forest make any noise?
[Linked Image] [Linked Image]
Pierre
Pierre Belarge
I've hidden a panel behind a picture myself. As for the hook, I used a magnetic backed piece of metal with a prong bent out to hang the picture on. Magnetically stuck to the steel panel cover. The botton of the panel does extend an inch or so below the bottom of the picture. No nail to find a wire with, and I can easily remove the magnetic hook before the electrician comes [Linked Image] Just hope nobody decides to loosen the panel cover screws and slip the picture hanging wire over and behind the cover....
At least the desk wasn't up against the wall; all you had in the way was a chair on wheels.
[This message has been edited by wa2ise (edited 01-10-2005).]
