227
28
Posts: 3,672 Likes: 4
Administrator Member
aww... you should have taken some "before" pictures too
This IS the "before" pictures!!! Can't you tell that crack in the second picture needs to be caulked?
This is a very typical service in my neighborhood. The vertical conduit ran through a concrete pad. When the pad settled it pulled the conduit out of the meter socket. I did a service across the street last year that had done the same thing.
The distribution panel is a Federal Pacific. The electrical contractor saved where he could, as breakers were available at the time.
This was a pretty good job except the commute was a killer (90 seconds).
I was going to post some "after" pictures, but I'm not sure I want the vultures picking on my bones.
Dave
Hi Dave, What's the white wire coming from the top right switch down to the neutral bar for?? (4th picture). ![[Linked Image]](https://www.electrical-contractor.net/ubb/confused.gif)
Posts: 8,450 Likes: 4
That's not a neutral for a GFCI is it, Electure?. Just a wild guess.
That's two different wires, guys. It does look like one, but they must cross on the right to look like one. The upper connection was a 240 volt circuit for the clothes dryer.
Dave
The pipes pill out of the meters around here too. They say with groung freezing things can move around a bit. Plus not compacting the soil. We take those uot and put in a underground pedistal.
Besides the meter did you pass your inspection Dave? Doesent anything pass in Crystal Lake?
2 more from Dave: ![[Linked Image]](https://www.electrical-contractor.net/Forum/Images/Resi_Upgrade6.JPG)
Is that a new idea on phase id? Black, black, black, black, black, black, red, red.
My work passes everywhere,Tom, doesn't yours? The colors are the different wire guages.
Dave
