1,052
13
im guessing its for cutting emt or flex or the like with a hacksaw when a bench or vise isnt close at hand....? whats my prize? or whats the penalty, never seen or heard of one before,just looks feasible!
Posts: 7,413 Likes: 10
Some type of fuse puller, or a tool to install/remove the tension springs from 'jaws'????
Close but no cigar?????
Looks like something out of an underground jointers kit may be!!!Very early Eddison
OK, here's my guess-
Maybe it's a tie wire wrapper for knob-and-tube wiring; it looks like a porcelain knob would fit in the "U" portion. Then again, actually using this to do a complete tie-wire wrap may be a physical impossibility...
This one's really got my head a'scratchin'!
No wire bias here- I'm standing on neutral ground.
I think Scott is messing with us and it is actually an old table leg...
Its a torture device for homeowners that do their own electrical work and handymen. ![[Linked Image]](https://www.electrical-contractor.net/ubb/wink.gif)
sparkystudent is right. Los Angeles used to allow up to 100' of aluminum flex to serve as an equipment grounding conductor if it was cut with one of these. I haven't used it since the early '80s. It doesn't work worth a darn... ![[Linked Image]](https://www.electrical-contractor.net/ubb/biggrin.gif) S
I'll be darned. Never would have guessed that. And I've been using the Benfield Saw Box for over 20 years. . . Were the two little hooks a way of sturdying the tool and flex while cutting?
Al Hildenbrand
E57, I just typed in "adjustable nut driver" at www.ebay.com There is one for sale right now. (I'm not gonna bid, just wanted to know what one looked like. The pic doesn't show it very well)
Al, See! You've already got one. As far as I can tell, the little hooks are there just to make it harder to put the hacksaw in...S
