Insert wire into a little hole. Tighten the grub-screw (set screw for americans).
Pretty uncommon for Austrian/German devices. Plugs and inline cord switches usually have set screw terminals.
There are two kinds of screw terminals that were used until the end of screw terminals. Either the compression plate variety where the wire is pushed into a hole and tightening the screw pulls a compression plate onto the wires or a stabdard screw with a big head where the wire is pushed under the head of the recessed screw, so it can't escape sideways. The latter method was very very common, the first was mostly used for the ground terminals.
Personally I've yet had to see a (European) backstabbed receptacle fail! With those I used (both cheapest Kopp and very reputable (and helluva expensive) Berker) It is close to impossible to pull out the wire without pushing the lever, you'll more likely break the wire.
Besides... you can't buy anything else here any more, so it's useless to complain! Apart from walmart-like Aldi/Hofer products no receptacles or switches have screw terminals or have had for years! 15 years ago most reputable manufacturers had already switched over to push-in terminals!
Regarding the choc blocks: you usually insert several wires (depending on the size) into one hole, so it's not as if each wire got it's individual screw! And adding or especially removing wires hot... yeah, it can be done, but removing wires will most likely cause at least some flickers to the other wires.
