0 members (), 1,230 guests, and 18 robots.
#111000 08/17/06 05:58 PM
Ron:
It's not a definite 'no-no'; permission is required. PS is still funny about that. Used to be 'to prevent unauthorized access to energized conductors, BEFORE the meter'.
A call to one of the PS Wiring Inspectors, and a quick site visit will get 'permission' if the condulet is the logical way to go.
#111001 08/17/06 10:03 PM
Can't blame the POCO for not wanting to get robbed by a customer :-)
#111002 08/18/06 06:46 PM
V
Ok, I agree that it looks bad but is there a code violation? I don't see one. I am guessing that the guy used a "liquidtite" connector becasue of the name, but they also used a FA before the connector. Odd yes, violation, don't think so. Just odd.
Pete
#111003 08/18/06 08:20 PM
VA:
Based on the pics, and the comments above I THINK it's a FA to a straight ST Conn to a little pc of ST to the ST 90.
Violation?? Sorry to say there's nothing I could write a 'RED" for. Workmanship is not a 'RED" offense in NJ
ALAN:
As I described the meter end of the raceway, is that how it is?? Or, is that a pc of PVC btwn straight & 90??
[This message has been edited by HotLine1 (edited 08-18-2006).]
#111004 08/18/06 08:48 PM
Alan, why did you tag it for the fittings?
The major Code violation was the use of a fitting for liquid tight flexible conduit on rigid non metallic conduit.
#111005 08/20/06 12:29 PM
There was no seal tite going into the fitting. The nonmetallic connector was jammed into the 90' fitting.
NEC 110.3(B) applies.
Alan--
N.J electrician mentioned the key. They should have used a meter socket with a top hub and saved two of the 90's
Alan--
#111006 08/20/06 03:41 PM
I have to say that when I zoom in on those fittings here is what I see from left to right.
PVC Female adapter, liquidtight straight connector with lock nut, a very short section of liquidtight, finally a liquidtight 90.
It looks ugly but code compliant in the picture.
#111007 08/20/06 03:50 PM
#111008 08/20/06 06:37 PM
Studying the picture, you seem to be right, it has been too long for me to remember it exactly.
Alan--
Alan--
#111009 08/21/06 09:18 PM
Actually there is one thing keeping it from being water tight. Any guesses?
Allen
