0 members (), 1,028 guests, and 9 robots.
#110641 05/30/06 08:03 PM
From Sierra-Electrician (aka Rob)
A real nice find in Sunnyvale, CA
This 2" run is from a separate metered service, it passes through this
service and goes under ground with no connector to the PVC...as if that
matters.
The service it passes through was installed 3 years ago and was
inspected.
#110642 05/30/06 08:28 PM
ARE LIVE BUSS BARS DOWN THERE!?!?! Is that metal raceway? Or is that just a neutral/ground buss and/or plastic raceway?
That looks real scarey!
#110643 05/30/06 09:02 PM
Its a Sq D I-Line M/M + Dist, the busing you see is the "A", "B" & "C" phases. Its 120/208V 3P, 4W.
The raceway is 2" alum flex secured with ty-raps to the gear structure. There is about 1" clearance between the conduit and the bussing.
Rob
#110644 05/30/06 10:55 PM
I just had a (one) beer...it must have been exceptionally potent- I think I see where someone snaked flex through some switchgear, right along some hot busbars.
This cannot possibly be the case- no one can be thet ignorant / stupid / daring / lucky.
Either that, or it is special "Bangalore" flex.
#110645 05/31/06 05:52 AM
K
Would it be corect to assume that whoever installed the 2" run could lose their license ?
#110646 05/31/06 09:04 AM
Why bother with the flex in the first place? At least if the raw THHN's were exposed in there it would be safe. However I remember anything entering a panel must terminate there as well?
#110647 06/01/06 11:15 PM
Is that flex conduit metallic or plastic ?
Whichever clown who installed that conduit, must have used 8 out of it's 9 lives.
If that conduit is metal, that's illegal to run it across live busbars in such close proximity without any form of insulating shielding.
#110648 06/02/06 02:08 AM
Nah Ray,
It looks like that cheap stuff we used to get here for Air Con installs.
Half the quality of Betta-flex and easily crushed by an over-tightened cable tie.
Even Vacuum cleaner hoses have more mechanical strength. [Linked Image]
#110649 06/02/06 11:18 AM
From Sierra Electrician
Sure looks like flex when it makes that bend and goes upward at the side of the enclosure.
RUN away, very far away!
Edited to fix UBB
[This message has been edited by CaOperator (edited 06-02-2006).]
#110650 06/10/06 02:45 AM
These are easily the most terrifying pics I've seen on ECN.
Flex can be a dangerous raceway in the hands of the insane.
Tesla
